02 sensor trouble
Old Apr 5, 2016 | 8:30 PM
Aaron4020's Avatar
Default 02 sensor trouble
Hi guys! I'm desperate for some answers. I have a 2008 Silverado. 5.3 with 115,000 on it. I ve had it for a couple years with no problems at all. I was driving it the other night and all of a sudden it started running like crap and missing and bucking ect. It throws a code for bank 1 #1 no activity and bank 1 #2 low voltage. I replaced #1 and it didn't seem to help much. But after a few miles it seems to clear up. I clear the codes and let it cool off. Then try again. Runs terrible for a few miles. Throws the codes again. Then seems to clear up. It will idle good for a 10 seconds or so then it starts missing really bad. I tried unplugging the battery for a while to reset the computer. Didn't help. Any help would be appreciated!
Old Apr 8, 2016 | 3:25 PM
CNG Pete's Avatar
Bank 1 #1 what??
Need more specific info to try and help you.
-Pete
Old Apr 9, 2016 | 1:53 PM
Aaron4020's Avatar
Bank one 02 sensors
Old Apr 9, 2016 | 2:21 PM
Aaron4020's Avatar
Update:
I changed both 02 sensors on bank one and changed the plugs. Still doing the same thing and throwing the same codes. Help!
Old Apr 9, 2016 | 4:40 PM
cleveland63b's Avatar
No other codes at all? Did you use OEM parts? If you have access to a scantool you need to see what/if the fuel trims and 02 sensors are reading. A lot of times 02 codes are set as a result of another issue not always just from the sensors. If its missing on startup or at all you need to figure out the misfire before you go after the 02 sensors.
Old Apr 11, 2016 | 7:35 AM
CNG Pete's Avatar
Thats the fun part of working on newer vehicles. Codes arent always an indicator of the fault, just that a fault exists.
-Pete
Old Apr 11, 2016 | 8:29 PM
but its so easy...after all the computer tells you what to fix...
Old Apr 15, 2016 | 7:11 AM
CNG Pete's Avatar
No it doesnt. If you made "repairs" for every code that popped up you would be out a lot of $$ and still not have a good running vehicle.
Sometimes the code is a precise indicator for a failed part.
-P
Old Apr 15, 2016 | 1:37 PM
that was sarcasm btw
Old Apr 18, 2016 | 3:48 PM
CNG Pete's Avatar
OK, now I know to re-think your commentary.
-P
