Old Jul 23, 2015, 5:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brakes
Print Wikipost
2008 Silverado cruise control is not working
Old May 16, 2021 | 4:49 PM
  #91
Aaron Sanford's Avatar
Default You’re my hero
Originally Posted by ram49
I pressed on the set button and a the same time kicked the brake pedal a
couple of times and the cruise came on. What is involved in changing the brake switch ?
I need a quick fix in a pinch, and this worked!!!
Old Nov 15, 2023 | 6:20 PM
  #92
Evie76's Avatar
Default Cruise control switch
Mine to! Stopped working last year. Where is this switch by the pedal located? What's it called? Im gonna go look to see if mine has one. (Fingers crossed)
Old Nov 23, 2023 | 5:01 AM
  #93
Mian's Avatar
have bought the switch at both Advance Auto and O'Reilley's a couple of times. They always have them in stock. However, I have had to replace them on 3 occasions, so I am on my fourth switch. Not sure if the off market ones are just bad or there is something wrong with the GM electronics. Either case could be likely...
Old Jun 2, 2024 | 5:19 PM
  #94
SkeeterHawk01's Avatar
Originally Posted by Jay2536
My cruise control just went out on my 2008 Silverado. I knew nothing about the break switch so I will try that this weekend. I've always been a Chevy guy, but it's unreal all the issues I've had with this truck. Replace 4 door locks (1 not under warranty) replace the sunroof because of a leak (under warranty) replace cracked dashboard (not under warranty) now this. Seems like a lot of problems for a truck that's supposed to be "like a rock"
I love the truck but man!
. Have the AFM lifters failed yet?
Old Aug 28, 2024 | 3:27 AM
  #95
Tkessler999's Avatar
Default Abs + traction control
2010 siverado 1500
I removed the stop switch to clean it in an attempt to get the cruise control to work. This was successful. However after replacing the switch now the ABS and Traction control malfunction light are lit. The do go off with the ignition but turn back on shortly after starting up. Any ideas what the problem might be?
Could this be cause by moving the brake pedal shaft?
mossyoak
16
Apr 12, 2023 8:40 AM
dorr0002
Dec 13, 2021 11:06 PM
chevyridinghi
Jun 4, 2009 8:07 PM
marilove
Oct 13, 2008 8:15 PM
AviD
Jun 26, 2007 10:41 AM
