Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Stereo Diagnostic
Guide to diagnose trouble and recommended solutions.
2008 Silverado Radio/Speakers issue
Basically this is what I am experiencing and if you follow this thread, this issue was solved with a new pair (L&R) of 6.5" speakers, so I don't think it's a short until I change my speakers as well.
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> lonas08Z71,
It sounds as if there is a short somewhere. Have you had the system inspected?
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> lonas08Z71,It sounds as if there is a short somewhere. Have you had the system inspected?
Louis
GM Customer Service
I know what the problem is. The stereo and the speakers are garbage. This is my third Chevy truck, though I am an audio nut. I prefer the ultra high end of the range. The stuff I have taken out of my trucks is the ultimate crap.
Just bought a 2010 Silverado and the stereo and speakers are garbage. That is alright I tokk all my stereo stuff out of my old truck. Just a matter of time of getting it put in my new truck.
Than it will be bliss again.
Good luck with your problems.
08 Silverado ex cab, door speakers kaput. Removed L front, checked with meter dead. Have a 99 Suburban with over 140.000 miles,speakers work fine. So I guess quality of parts has declined. Died in the wool Chevy man, dont like the word F---, but maybe I'll change. They didn't have to be bailed out by US. Must be a quite a few people with speaker problem. How about it Chevy rep. Send me new speakers I'll put'm in myself.
Sounds like a ground wire to me if more then one thing is broke start at battery work backwards
If it was hot wire it would not work and come on and off so its getting ground just not 100% I know you guys looked but keep looking its there
Join the club! You'll have to change them all out as I did with some real speakers. Best advice is get an audio shop to do it as the trim does not remove as easy as they used to plus dealing with the auto windows and locks are a bitch.
Yep, same prob with an '02 Silverado. Got a set of Kicker speakers for the front doors from Crutchfields for $62.00 shipped. All is good now. Installation was pretty straight forward. Saw a video on youtube, door panel removal.........these speakers are better than OEM..........Ed
I just removed mine today. I have a Hanes repair manual it should tell you everything you need to know. All I had to do was pop out the plastic trim piece then there are two bolts on your ac control and four on your stereo you should be good from there just be careful with the anti theft lock out because it will cause your truck not to start then you will have to take it to a dealership
