2008 Silverado Stuck In 4 Hi. Any Ideas?
Old Jun 25, 2010 | 12:03 AM
survey101's Avatar
Default 2008 Silverado Stuck In 4 Hi. Any Ideas?
Ive had truck 2.5 years and put 106,000 miles on it on pipeline right of ways and have few complaints in that time. But recently after using 4 wheel drive to get up a pretty steep hill on the way back down i turned **** back from 4hi to 2hi but light stayed on 4hi and it stayed in 4 wheel drive. This has happened to me 2 times previously and both times after doing exactly what it says in manual I have been able to get out of 4wd fairly quick. This time took longer. How can I manually disengage 4wd or can I even do that? I sure dont like to drive down the highway 65 mph in 4 wheel drive.
Old Jun 25, 2010 | 12:18 AM
LARIDERS's Avatar
if it is stuck in 4hi I think the only way to do it would be to pull the front drive shaft. maybe someone on here will have a better way that is not as hard.
Old Jun 25, 2010 | 3:58 AM
juliechristie25's Avatar
What have u done to live it in fashinable world?!!!!! Check Here
Old Jun 26, 2010 | 1:26 AM
Mille Racer 69's Avatar
So you have automatic locking hubs I guess...
have you switched into and out of 4wd before?
when you try to switch it is there a grinding noise or is it just stuck?
Old Jun 26, 2010 | 5:48 PM
Old Coot's Avatar
Haven't had that problem with the newer drivetrains. But, with the old style you could jack up the front wheels to release the tension on the running gear and it would pop out. Backing up for a ways will also work sometimes. Hope it is nothing bad wrong with it.
Old Jul 17, 2010 | 7:47 PM
dungholio's Avatar
check your tires...... if you haven't rotated them in a while, and the rear tires are more worn than the fronts...... then whats happening is the tires are spinning at different speeds, which causes the 4wd system to actually get its self in a bind... so when you try and switch it out of 4wd, the switch actually gets stuck.... the only way to totally fix the problem is to replace the tires... no matter which way they get rotated it will not fix the problem
Old Dec 10, 2023 | 4:23 PM
Robinson1509's Avatar
you can remove the axle actuator and dial out the plunger to disengage the wheels, however the transaxle may still be engaged.
Old Dec 10, 2023 | 6:52 PM
Rednucleus's Avatar
Welcome to chevy Robinson1509 - usually no good responding to a 13 year old thread
Old Dec 10, 2023 | 7:06 PM
@Rednucleus
it might help someone who comes searching
shayneneal
Aug 27, 2009 5:52 PM
jcskys
Jan 2, 2009 4:04 AM
JTraven572
Mar 2, 2007 2:09 AM
Dragon18
Apr 10, 2006 9:00 PM
