2009 z71 tranny
Old Nov 2, 2023 | 8:35 AM
Caitlyn08's Avatar
Default 2009 z71 tranny
On my 2009 z71, reverse will kick out and grind/spin sometimes. 88xxx miles, also feels like some tugging up hills. No engine lights.
Old Nov 2, 2023 | 4:17 PM
manual or automatic?
Old Nov 2, 2023 | 4:21 PM
Caitlyn08's Avatar
It is an automatic. With the 5.3. Mostly in reverse.
Old Nov 2, 2023 | 5:00 PM
unfortunately , grinding indicates a failed transmission. It has to be replaced.
Old Nov 2, 2023 | 5:07 PM
Caitlyn08's Avatar
It only happens sometimes when I put in reverse and quickly give it has. If I'm easy on it, it's fine. And there is no other sounds from it. When it kicks out, it's like a higher sound the goes with the rpm. Almost like an electrical grind. Not a real metal to metal grind. If this makes any sense.
Old Nov 2, 2023 | 5:20 PM
I hear ya. Unfortunately the answer is most likely still the same.
I assume you did the obvious and checked the transmission dipstick.
You can try taking it to a transmission specialist shop so they can run a diagnostic and check it out for you.
If you're feeling adventurous, you can drop the pan yourself, and see what comes out.
Old Nov 2, 2023 | 5:27 PM
Caitlyn08's Avatar
Fluid is all good, and clean. But will do some more investigation
Jona4495
2007 - 2013 (GMT900)
Oct 25, 2023 11:24 AM
FrankP
Aug 28, 2020 1:10 PM
NBSilveradoMan
Sep 28, 2008 10:58 AM
