2009 z71 tranny
It only happens sometimes when I put in reverse and quickly give it has. If I'm easy on it, it's fine. And there is no other sounds from it. When it kicks out, it's like a higher sound the goes with the rpm. Almost like an electrical grind. Not a real metal to metal grind. If this makes any sense.
I hear ya. Unfortunately the answer is most likely still the same.
I assume you did the obvious and checked the transmission dipstick.
You can try taking it to a transmission specialist shop so they can run a diagnostic and check it out for you.
If you're feeling adventurous, you can drop the pan yourself, and see what comes out.
