2010 chevy silverado radio problems
Old Mar 13, 2013 | 9:33 PM
Maine23's Avatar
Default 2010 chevy silverado radio problems
My radio turns off and display auxiliary device input. Does anyone know what that means?
Old Mar 14, 2013 | 2:16 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Maine23,
The radio turns off by itself? Is there a plug plugged into the auxiliary port or USB port? Devices that could use the auxiliary port are iPods, MP3 players, CD changer, USB storage device, etc.
If you press the “SRCE” button, it should switch between the radio, CD, and for vehicles with DVD, front auxiliary and rear auxiliary.
Please contact me privately if you have additional questions.
Louis
GM Customer Service
Old Jun 18, 2013 | 9:58 PM
Maine23's Avatar
Default 2010 towing mirrors
I have bought a replacement towing mirror for my2010 chevy silverado 2500hd. Is there a way to replace it without taking off the door panel? Maybe replace it at the knuckle.
Old Jan 18, 2014 | 9:10 AM
behappy25's Avatar
my radio is doing the exact same thing. I called our local dealership and they haven't heard of it happening. Im kinda upset.
Old Mar 21, 2014 | 5:06 AM
Heavy-Chevy2500hd's Avatar
my CD player went out in my 05 2500hd. it will play them, just want receive or eject cd. I have to use 2 pocket knives to remove it lol. is there anyway to fix it, I was ooa check before I buy a new one. thanks
Old Nov 28, 2014 | 8:48 PM
bmeadows's Avatar
Default 2010 Chevy Radio Problem
Mine is doing the exact same thing. Anybody know what causes this?
Old Jan 23, 2015 | 10:04 PM
robpaulson's Avatar
Same thing is happening to me. From what I read from this site and others it's either the wiring in the steering controls, aux plug in is loose, loose wire in the back of head unit, or aux wiring needs soldering. Since mine seam to happen when it's bumped, either by the road or if a passenger hits the side with their knee, I'm going to pull out the stereo and see if any wires are loose. I don't have the money to fix either of the other problems so I'm praying that a loose wire is the problem.
Old Apr 19, 2015 | 9:11 AM
johnrmaples's Avatar
Default Aux Device Input
Mine is doing the same thing. The radio will be playing, then suddenly silence and displays "Aux Input Device". Back and forth between radio and this. I almost cannot listen to the radio any more. Doesn't matter if I push the Source button, turn the radio on/off, nothing.
Advice???
Old Jun 25, 2015 | 10:15 AM
BigHankRollins's Avatar
Advice???
John, I have SAME exact issue. Aux port was a little loose. I took the entire radio dash mount off (easy) and the radio face, but tried a little glue instead of solder (i know, i know) but still have issue. Did you get this resolved??
Old Dec 11, 2015 | 11:30 PM
Freeway03's Avatar
I have a 2013 Silverado LT. Mine does the same thing. Nothing plugged into auxiliary or USB, but the radio will switch to auxiliary input device. If I hit the top of the dash it will switch back. Doesn't matter if I'm listening to xm, fm, or am.
