2011 GMC Sierra 1500 4.8L 4X4 (Silverado) No power to fuel pump
Old May 4, 2022 | 3:55 PM
MorganAutomotive-John's Avatar
Default 2011 GMC Sierra 1500 4.8L 4X4 (Silverado) No power to fuel pump
I work at a small local shop....
Currently we are working on 2011 with no power PAST the relay for the fuel pump. New relay, swapped relays, and replaced #20 fuel pump fuse.
We have also tried to apply power to the fuse via power probe, also checked for power at the relay have both a 12v signal to the relay, and a ground to the relay but no power to the fuse with key on or when cranking.
Based on what I have read thru alldata and on other forum posts, I should be getting power to the fuse if I have power at the relay.
Vehicle was towed in.....
Electrical is NOT my 1 of my strengths but I can usually work thru it.... however this 1 has me kinda stumped.
Old Feb 22, 2024 | 9:55 AM
Cowby21j's Avatar
did you end up getting the issue resolved? If so what was it? I'm currently having same issue
Old Feb 22, 2024 | 10:35 AM
We did, however I can't remember what it was that fixed it ... Been 100-150 cars thru here since then
Old Feb 2, 2025 | 8:17 PM
Miniondave's Avatar
Default No power to fuel pump
I'm not sure if this is an anomoly or what, but after a few days of head scratching, my issue with the fuel pump turned out to be a broken wire in the bundle just below the filler neck. I could see a black wire chafed, and after I opened the bundle, found the fuel pump wire had corroded and was all but broken in half.
Chevy Silverado 4x4
Dec 26, 2021 8:31 PM
Zekester65
Aug 3, 2019 10:58 AM
Robertt
Apr 30, 2019 12:58 PM
trainwreck91
Sep 14, 2016 9:32 AM
hunter10220
May 18, 2011 8:37 PM
