2013 Silverado Driver Side Window
Old Mar 12, 2024 | 12:01 PM
tprokop's Avatar
Default 2013 Silverado Driver Side Window
My driver side window stopped working recently. I replaced the window switch without any luck and now have replaced the window motor. During install of the window motor we tested the window prior to putting the door panel back together. The window worked perfect and reinstalled the door panel. Tested the window once the door was put back together and it would not work again. Yesterday I took off the door panel looking for something loose or exposed wires and nothing is out of the ordinary. Any thoughts what the issue might be? The passenger and rear windows work just not the driver side. Any thoughts are greatly appreciated because this has me stumped and frustrated.
Old Mar 12, 2024 | 1:08 PM
Did it work again when you took the door panel back off? Jiggle the wires to see if it starts to work. Make sure the motor is grounded well.
Old Mar 12, 2024 | 1:20 PM
tprokop's Avatar
No, it did not work when I took the panel off after install. I checked the wiring and made sure everything was secure that I could access.
Tmart67215
Avalanche
May 4, 2021 7:13 PM
Tmart67215
Avalanche
May 4, 2021 7:13 PM
highroad
Dec 6, 2014 8:22 AM
pose_master
May 2, 2010 1:23 AM
