Battery Going Dead
Old Aug 30, 2022 | 1:12 PM
BurghFan420's Avatar
Default Battery Going Dead
My 2011 Silverado's (124,000 miles) battery was changed 27 May after the old one lasted almost 6 years. I bought O'Reilly's best battery (Platinum series). End of June after 7 days sitting in the garage without being run, the battery was dead. I took it back to O'Reilly's and they tested it, and battery was dead, and the charging system was working. They gave me a new battery. Since then, the battery has gone dead twice, each after a 6- or 7-day period. I am guessing the truck is causing the problem. I do not see any interior lights on that would drain it. Scared to take to dealership or local shop until i do some research on this problem. Anybody go thru this on their vehicle where it was not a light on. Is Computer powering something that I can't see or hear?
Old Aug 30, 2022 | 4:30 PM
kevinkpk's Avatar
Something is drawing excessive current, with a voltmeter on the battery, disconnect i.e. pull indidvidual fuse's see if/when the volt meter stops showing the voltage drop, that's it. Excess current in in the mili-amp range.
Old Aug 30, 2022 | 7:35 PM
Thanks for the idea of pulling the fuses. I have a clamp-on meter arriving tomorrow that will read DC amps. Thanks again
Old Aug 31, 2022 | 3:07 PM
kevinkpk's Avatar
You really just need a voltmeter.
mstewart39
Jul 9, 2017 7:14 PM
Scotiapilot
Mar 15, 2016 12:35 PM
TAHOE2005
Jun 1, 2010 9:19 PM
Tieffun
May 22, 2010 6:12 AM
ousig2408
Feb 18, 2010 12:40 PM
