Cooling System Hoses
Old Feb 23, 2023 | 10:33 PM
Rockrz's Avatar
Default Cooling System Hoses
Does anyone have the AC Delco part numbers for all the cooling system hoses for 07 thru 13 Silverado 2WD with 5.3L engines?
Old Feb 23, 2023 | 10:46 PM
Christcorp's Avatar
Well, for my 2007 2WD silverado with 4.8L engine (Same as 5.3L except bore), the part number for radiator hoses I list below. Bottom hose and hose to reservoir are about $39 each on amazon. The top hose is $68 on amazon.
I didn't list heater core hoses because those are pretty generic. Just go to oreilly, autozone, etc. and get about 10 feet of heater core hose (Correct diameter) and cut the length you need.
ACDelco GM Original Equipment 22827735 Radiator Outlet Hose (bottom hose)
GM Genuine Parts 22827733 Radiator Surge Tank Inlet Hose , Black (reservoir hose)
ACDelco GM Original Equipment 22827731 Radiator Inlet Hose (Top hose)
Mike
Old Feb 23, 2023 | 11:16 PM
Rockrz's Avatar
My heater hoses are definitely not generic. It's like an assembly of hoses coming together.
I wasn't to jerry rig it, but may have to if I can't find and OE style replacement
Here's a pic of the the section I'm speaking of...
Old Feb 24, 2023 | 1:05 AM
Christcorp's Avatar
Well, if you want, you can get ac delco/gm hoses. Here's a list below of part numbers for the various hoses. But you can also get 3rd party hoses for a lot less. Just check at autozone, oreilly, etc. or amazon
ACDelco Hose 30124
ACDelco Hose 18221L
ACDelco Hose 18206L
ACDelco Hose 34000
ACDelco Hose 22884219
ACDelco Lower Radiator Hose 15-34717
Old Feb 24, 2023 | 8:01 AM
Rockrz's Avatar
I can also use the AC Delco number to cross reference and get part numbers of other brands.
Gumby22
Aug 8, 2020 8:35 PM
Krashtrouble
Jul 1, 2013 8:21 PM
Got Options?
11
Jun 17, 2012 11:46 AM
resabed01
May 17, 2011 5:34 PM
dan1500
Aug 17, 2008 2:09 AM
