Grinding noise while turning
Old Apr 11, 2016 | 6:12 PM
Chevy1401's Avatar
Default Grinding noise while turning
I have a 2013 Chevy Silverado. When I am in the process of turning left I get traction and stabilitrack OFF and abs goes off. There is a grinding after this whenever I turn, right or left. I checked on front right side and everything seems intact. I've read multiple things on forums that it could be the emergency brake loose and and others say I need to replace the hub and sensors. Trying to see if anyone else has had this issue and get an idea before I start hacking away at the problem. Any help is appreciated.
Old Mar 25, 2017 | 8:05 PM
Robertwf's Avatar
I'm not sure but my 2008 Chevy Avalanche LTZ is doing the same thing and Monday I'm taking it to my mechanic to have him look at it. I'm new to this forum but if you find an answer could you please let me know and if I find out I'll come back here to let you know what I found out. Thanks!
Old Mar 25, 2017 | 8:33 PM
sounds like a bad wheel bearing about to fail. don't put a cheap bearing in if you are keeping it for more than 1 year....or you will be replacing it again.
