Hubby connected jumper cables incorrectly
Old Sep 17, 2017 | 7:51 PM
CBsduramax's Avatar
Default Hubby connected jumper cables incorrectly
Jumper cables incorrectly connected to the 2011 Chevy Silverado 3500 6.6 Duramax with Allison tranny. Now truck is D E A D
What do we check first? PS The truck was fine but the tractor needed jumped.
Old Sep 17, 2017 | 8:56 PM
kevinkpk's Avatar
If you haven't unhooked the jumper cables, do so. Let it set for a couple hours. It might come back. I'll also ask if the battery is ??? old, it' needs replaced.
Old Sep 18, 2017 | 8:35 AM
CBsduramax's Avatar
Lightbulb
Thanks I will try that first. I wondered if that would work, its worth a try.
Old Sep 22, 2017 | 1:35 PM
Matt B's Avatar
Check the Main Fuse.
Old Sep 25, 2017 | 8:45 PM
intheburbs's Avatar
Check the megafuses on the firewall, on the passenger side. IIRC, you'd have a 125-amp and a 175-amp in there. I'd wager that one of them got fried. They cost like $8 at an auto parts store.
Here's the location, circled in yellow. The cover just pulls off:
Once you've pulled the cover off, you'll see this:
If these are both intact, then it's likely that something got fried, like the powertrain control module, or the body computer.
