Ignition problems 2008 2500 HD 6.0
Old Feb 2, 2021 | 6:44 PM
quedude's Avatar
Default Ignition problems 2008 2500 HD 6.0
I have a 2008 2500 HD with the 6.0 gas motor. I was driving the truck and the check engine light came on and the truck lost power. I limped it home and found the drivers side cylinders were not firing. I have changed the coils, spark plugs, wires and the ECM. Also checked the fuses in the box that go to that circuit. I don't know what to look at now? I believe it is a electrical just don't know were to start?
Old Feb 2, 2021 | 7:33 PM
oilcanhenry's Avatar
Can you give us some OBD II codes?
Old Feb 2, 2021 | 8:16 PM
quedude's Avatar
codes
p0351
p0357
p0357
p0355
Old Feb 3, 2021 | 8:39 AM
codes
p0351
p0357
p0357
p0355
Sounds to me like a Faulty Powertrain Control Module (PCM).
Old Feb 4, 2021 | 7:23 AM
quedude's Avatar
Already replaced the ECM. That was the first thing I did.
Old Feb 8, 2021 | 1:08 AM
Could have a bad MAP sensor. They can sometimes be cleaned with brake cleaner if dirty or the connection
has some corrosion.
It's usually a code P0106, but it's possible it won't show a code.
Did some more research on your issue, and it was the O2 sensors that were the issue.
Smazze
Jul 5, 2020 4:19 PM
ProvenDesign
Jul 20, 2011 8:49 PM
flstfse
Mar 24, 2008 7:26 PM
thrasherff
Dec 28, 2007 12:24 AM
