Ignition problems 2008 2500 HD 6.0
I have a 2008 2500 HD with the 6.0 gas motor. I was driving the truck and the check engine light came on and the truck lost power. I limped it home and found the drivers side cylinders were not firing. I have changed the coils, spark plugs, wires and the ECM. Also checked the fuses in the box that go to that circuit. I don't know what to look at now? I believe it is a electrical just don't know were to start?
Could have a bad MAP sensor. They can sometimes be cleaned with brake cleaner if dirty or the connection
has some corrosion.
It's usually a code P0106, but it's possible it won't show a code.
Did some more research on your issue, and it was the O2 sensors that were the issue.
has some corrosion.
ProvenDesign
Jul 20, 2011 8:49 PM
