Low oil pressure alarm
Old Mar 23, 2021 | 9:32 AM
t.mcginley.jr's Avatar
Default Low oil pressure alarm
Hi all, just bought a 2007 Sierra 2500hd 6.0 gas truck with ~230k miles on it.
When the truck is warm and idling, the low oil pressure alarm will start to chime and then go away once you accelerate. I know the common problem is the oil pressure sensor itself, or more likely the screen under it. The problem is I pulled mine and there was no screen. I'm guessing at this mileage it's possible I do actually have low oil pressure?
I've seen on another thread where sometimes it's just the o-ring between the oil pump and pickup tube that causes the low pressure.
Old Mar 23, 2021 | 11:36 PM
have a shop test the oil pressure when its warm using a master gauge. this will tell you if the trucks gauge is accurate. if it is....maybe the oil pump is tired. maybe the bearing clearances are excessive.
Old Mar 24, 2021 | 9:53 AM
Rednucleus's Avatar
What oil viscosity are you using? If verified low pressure as Tech says, you could try increasing viscosity. My 93 suburban with 350k does the same thing with 5-20. Using 20-50 gives me 10 more psi.
Old Mar 24, 2021 | 2:22 PM
I probably should have diagnosed this further before tearing everything down, engine is already out of the truck. Here's a pic of the cam bearings, they look pretty worn. I need to pull the rod and main bearings still, and also see what the oil pump looks like.
Old Mar 24, 2021 | 9:27 PM
if you are at that point take measurements/plasti-guage
Madison Dees
Jan 7, 2024 10:05 AM
Curt Davis
Dec 31, 2020 3:01 PM
TWard
Jan 3, 2020 5:53 AM
Rich Quezada
Sep 9, 2018 8:26 PM
ironcross1986
May 3, 2010 11:07 AM
