need help IDing transfer case
Old Jul 30, 2025 | 10:40 AM
catmech's Avatar
Default need help IDing transfer case
I have a 2008 sierra 1500 with the manual shift transfer case with RPO code NQG,the RPO code list I found online does not have
NQG on the list and I need to buy some parts.Can anybody tell me what transfer case I have?
Thanks for any help.
Old Aug 26, 2025 | 5:40 PM
Suburban Dude's Avatar
Default Nqg = 1226xhd
Hello. The NQG is a 1226XHD but is normally found on a 2500HD or a 3500.
Is your truck a 1500 HD? There were some built.
Old Aug 26, 2025 | 11:07 PM
catmech's Avatar
Information was hard to find but the 1500 uses the MP1222 transfer case the 2500 uses the MP1225 and the 3500 uses the MP1226
transfer case but they all use the RPO code NQG.The differences are in the number of splines on the shafts and the width of the chains.Some good information here.
https://www.transmissiondigest.com/m...-cases-part-2/
Old Sep 1, 2025 | 10:03 AM
dpieroni3's Avatar
The NQG transfer case is available in 3 variations, depending on the engine and transmission configurations. The variations allow the transfer case to handle different torque loads. When servicing the transfer case it is important to understand which variation is being serviced because of the difference in parts.
MP 1222/1225/1226 VariationsModel
Transmission
Input Shaft
Output Shaft
Chain Size
Chain Series
Hi/Low Planetary
Application
MP 1222
Light Duty (LD)
M30 – 4L60-E
27T
Spline
32T
Spline
7/16 X 1.25 in
9600 Series Rocker Pin Chain
3 Pinion
K1
MP 1225
Heavy Duty (HD)
MYD – 6L90
29T
Spline
31T
Spline
7/16 X 1.5 in
5 Pinion
K2
MP 1225
Heavy Duty (HD-Canadian)
MYD – 6L90
29T
Spline
31T
Spline
7/16 X 1.5 in
2300 Series Round Pin Chain
5 Pinion
K2
MP 1226
Super Heavy Duty (SHD)
MYD – 6L90
MW7 – Allison
29T
Spline
31T
Spline
7/16 X 1.5 in
5 Pinion
K2, K3
Hope this helps. It's from GM SI document 1822366
Daniel Acosta Sr
Jun 22, 2020 10:07 AM
Robert Sakee Glenn
Apr 23, 2016 11:22 AM
woodyjr09
K5 Blazer
Apr 3, 2016 2:46 PM
muddracer
Jan 1, 2015 5:07 PM
