No hi beams
Old Mar 6, 2021 | 8:16 PM
kenndb55's Avatar
Default No hi beams
Has anyone figured out a way to replace the hi beam relay on the bottom of the fuse block?
Old Mar 6, 2021 | 10:25 PM
if the relay is part of a printed circuit board you can:
1. de-solder the old relay from the pcb and solder in a new one.
2. an easier option is to install a weather proof external relay. using a wiring diagram and connector pin out diagrams...cut the correct wiring to the pcb relay and splice the wiring into the new relay.
3. replace the entire fuse block
Old Mar 8, 2021 | 7:11 AM
kenndb55's Avatar
any step by steps on the replacement or external relay for those of us less knowledgeable or experienced in such matters?
Old Mar 8, 2021 | 9:31 AM
i don't know any.
try google.
Old Mar 15, 2021 | 5:36 PM
Lucas Theriault's Avatar
I also had no high beams I took the under hood fuse box out and the connections for the headlight harness where severely corroded cleaned them up now my high beams work perfectly. I also had power at both left and right high beam fuses.
aaronscott8108
Jan 5, 2019 2:13 PM
Dan Y
10
Dec 26, 2016 3:58 PM
cripkd
Sonic (Aveo)
Nov 9, 2015 4:09 AM
jasonv
Mar 29, 2013 10:28 PM
JHarris8732
Feb 13, 2012 8:16 AM
