Oil blowing everywhere
Old Jan 17, 2024 | 3:02 PM
Durrance1998's Avatar
Default Oil blowing everywhere
I have a 2011 Silverado that is supposed to have the 6.2 in it but actually had the 5.3 in it when I bought it. It started throwing oil through a hose that runs from passenger side valve cover and into breather tube. It gets into the intake and exhaust smokes bad. I put new pistons and rings in it and 1500 miles later it is doing the same thing. Already replaced pcv valve and drilled out the baffle. The first time I lost compression on all 4 cylinders on driver side. So far this time I have only lost compression on 1 cylinder. What would cause it to do the exact same thing? It pushes about 1-2 quarts a day through the breather tube and into the intake.
rafteredd
2007 - 2013 (GMT900)
Aug 29, 2019 5:56 AM
JPTL
Jun 28, 2019 1:52 AM
rdnkrfnk
Jun 11, 2010 6:59 AM
Trupster
Jul 8, 2007 6:26 PM
