P0521 - Oil pressure is actually good
Old Mar 17, 2023 | 3:35 PM
Ihave2manyKids's Avatar
Default P0521 - Oil pressure is actually good
P0521 code - gauge on dash reads 20-25psi at idle
Things I have tried:
-Mechanical Gauge - reads 38psi at idle - I think this is the proper oil pressure for this engine
-Replace oil pressure sensor & screen underneath it
-Scratch my head
What are my next steps here?
Old Mar 18, 2023 | 1:35 AM
oilcanhenry's Avatar
38 PSI at idle is fine. Whats it run at 1500-2000 RPM?
Old Mar 18, 2023 | 7:16 AM
Hard to see my guage from in the cab because the hose is a little short but it definitly went up a few psi when I invreased rpm, maybe 45-55psi
Old Mar 18, 2023 | 11:40 AM
Todd Schmitz's Avatar
Talking
You could possibly have a dirty filter screen under the oil pressue sender behinde the intake manifold.
Old Mar 18, 2023 | 11:50 AM
As stated in my initial post, this has been replaced
Old Mar 19, 2023 | 10:28 AM
dpieroni3's Avatar
Assuming you have a 1500 pick-up with a 5.3L. Minimum oil psi spec for VIN 0 is 22@1K,30@2K,and 33@3k. or for vin 3 is 24@1k,35@2K, and 38@3K. All taken at the top end. The oil pressure gauges are really pretty accurate. What you also need is oil pressure reading from the bottom end taken with an adapter that replaces the oil filter. Oil pressure readings should be taken with the engine at operating temp. I have run across numerous repairs for this issue. What I do is get the engine hot and monitor oil pressure top and bottom. When the gauge gets low is when I install the test adapter in place of the oil filter because I have had many restricted oil filters. Something you can try is when the engine is hot and showing 20psi oil pressure at idle, just put on a new oil filter and restart it and see if oil pressure comes up. Usually will come up about 10 psi if the filter is restricted. Hope you find this useful.
Old Mar 20, 2023 | 11:17 AM
Thank you for this info.
It is the 5.3L vin 3 (LC9 engine)
I was taking my reading with my mechanical gauge at the bottom of the block, directly after the oil pump. I will check it again at the top where the sensor is to see if it is low at that point.
I do not have the oil filter adapter for my gauge, but maybe I will just change the oil and filter and see if that corrects it.
Old Mar 21, 2023 | 12:53 AM
Perfectly fine oil pressures!
Thomas Badger
Mar 11, 2020 6:40 PM
john432
Sep 9, 2015 6:46 AM
privatecarp
Nov 22, 2014 1:22 PM
hammergirl08
Jul 18, 2014 4:48 PM
sickmind333
Apr 23, 2009 4:51 PM
