Possible heater core leaking?
Old Oct 24, 2022 | 9:28 PM
ncsouthpaw's Avatar
Default Possible heater core leaking?
I have a 2012 2500HD with 6.0 lit. engine. I noticed a wet spot under the truck and after investigating I found water/coolant dripping from the rubber tube coming out of the firewall. If it is the heater core how big of a job is it to replace?
Any advise is appreciated
Ronnie J
Old Oct 25, 2022 | 7:22 PM
david starr's Avatar
Ronnie J
It is normal for condensation to leak out there. If it is water you are OK, if it is a mixture of antifreeze and water, you likely have a heater core leak. You possibly can find instructions on u tube, if not you will need to consult a shop manual for the procedure.
Old Oct 25, 2022 | 9:19 PM
ncsouthpaw's Avatar
Thanks, yeah I have recently noticed a loss of coolant. So I am pretty sure that is the culprit.
Old Oct 26, 2022 | 12:35 AM
oilcanhenry's Avatar
Good advise, David!
A/C Evaporators don't often cause issues, since R-134A isn't particularly corrosive, as H20 is. Problem is that lots of people don't change their coolant on time, and also never run the heater during hot summer weather, which flushes out the stale anti-freeze coolant, thereby preventing corrosion.
The OP's options are to use a sealant like Alumi-Seal, or Bars-Leaks, or spending lots of $$$ replacing the heater core, should that fail. .Underdash repairs are time-sensitive, thus making the work very labor quite expensive.
1993chevyg30
Nov 23, 2021 8:28 PM
Harry in Ky
Sep 26, 2019 11:55 AM
Viking08
Sep 28, 2015 8:44 PM
gaftop1
Apr 8, 2012 12:33 PM
jmack91z28
May 8, 2008 3:38 PM
