Steering wheel noise
Old Nov 8, 2017 | 4:54 PM
gpascott's Avatar
Default Steering wheel noise
2012 Silverado CC. I am getting a noise when I turn the steering wheel. Is this a common problem? Has anyone had this issue?
Old Dec 11, 2017 | 9:49 AM
Suburban Dude's Avatar
The fist thing to do is to change out your power steering fluid.The easiest is to purchase a turkey baster, buy some power steering fluid directly from GM, ( I don’t believe in universal power steering fluids). Use the baster to empty the reservoir. Fill it with fresh fluid. Take it for a drive and slowly turn lock to lock in a parking lot, remove the fluid again, fill, and repeat. I would would do a total of three fills to have 90% new fluid. Others would say you should take off the return hose and go for 100% replacement but I think it’s just extra work for what you get. If it’s still noisey or if your power steering pump is leaking you might consider replacing the pump.
SD
Old Dec 11, 2017 | 10:31 AM
gpascott's Avatar
SD
Thanks, I'll give it a try.
