2015 High Pressure fuel pump
Old Sep 18, 2023 | 4:13 PM
trprdav's Avatar
Default 2015 High Pressure fuel pump
I have a 2015 Silverado with a 5.3 that I’m doing an AFM delete on and while everything is apart I need to change the HP fuel pump as it’s not maintaining pressure and causing hard starts. The problem is that I cannot find a pump anywhere. Anyone have any knowledge as to where I can get one or if there is a replacement that would do the job?
Old Sep 18, 2023 | 5:08 PM
have you tried rockauto?
Old Sep 18, 2023 | 6:38 PM
trprdav's Avatar
Rockauto was my first choice. I have tried all of the major websites, even some sketchy ones, and every parts store I could think of. It seems like the part is discontinued and there are no aftermarket replacement options.
Old Sep 18, 2023 | 6:56 PM
https://www.buykippscottgmparts.ca/o...-pump-12711662
Old Sep 19, 2023 | 10:16 AM
trprdav's Avatar
It’s good to know there are some out there. The only down side to the place you sent is that they only ship within Canada, and I’m in the southern US.
Old Sep 19, 2023 | 1:47 PM
plenty more where that came from (web search)
https://www.gmpartscenter.net/oem-pa...-pump-12711662
https://www.gmpartsoverstock.com/oem...-pump-12711662
https://paceperformance.com/i-239188...fuel-pump.html
https://www.gatewaypartsonline.com/o...-quot-12711662
(you'll need to verify the part number yourself since you didn't provide one)
Old Sep 19, 2023 | 9:49 PM
trprdav's Avatar
I really appreciate the assistance! I didn’t know about these sites. Now I can finally get my truck finished and back on the road!
Old Sep 19, 2023 | 10:10 PM
I didn't know about these sites either. I just typed "gm 12711662" into google.
Old Jan 29, 2024 | 5:01 PM
georgecampa23's Avatar
Did your fuel pressure sensor go off too?
Old Jan 30, 2024 | 8:01 AM
trprdav's Avatar
No, fuel pressure sensor was fine. I began having long starts, or sometimes no starts due to the HP system only getting up to around 420 psi
Lakeman 903
Aug 28, 2021 8:10 PM
chadkirchner
Aug 7, 2015 1:03 PM
gumby197
Nov 6, 2010 12:55 PM
steve40
Sep 24, 2006 1:55 PM
