View Poll Results: Could it be faulty wiring or the brake module itself
Faulty wiring
50.00%
Bad module
100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
2015 silverado u0073 ebcm fault no abs light or check engine light
Old Mar 16, 2024 | 6:00 PM
Gaspar89's Avatar
Default 2015 silverado u0073 ebcm fault no abs light or check engine light
Hello everyone I've been having an issue with a 2015 silverado 4x4 5.3 a couple of weeks ago coming home from work my truck went into limp mode, it wouldn't accelerate and wouldn't shift past 2nd gear i got it home checked tranny and engine fluids found no issues disconnected the battery and got it going ,now it feels like its misfiring and struggles to accelerate I replaced throttle body, maf, map,sparkplugs, thinking it was an air fuel issue but it started making some rumbling noises at the wheels randomly (like rumble strips) i replaced wheel speed sensors ,inspected bearings, and found nothing out of the ordinary when i scanned it the only code its giving is u0073 ebcm communication lost there is no abs light or check engine light I have checked visible connectors, fuses, grounds, and wiring and the resistance on the can looks good from the obd port I'm trying to find schematics or any information ,assistance would be greatly appreciated thank you
Old Mar 16, 2024 | 9:37 PM
follow the troubleshooting here
https://www.obd-codes.com/u0073
cyoungwi
Sonic (Aveo)
May 12, 2022 11:14 AM
kjamesm
Feb 15, 2022 7:10 AM
Jrock1982
May 27, 2019 6:19 PM
nkeen07
Apr 23, 2015 10:10 PM
Skrappi
Oct 19, 2007 2:12 AM
