AC help needed. Pressure Switch
Old Jun 25, 2023 | 12:28 PM
Jster91's Avatar
Default AC help needed. Pressure Switch
I have a 2016 silverado 6.2L. I replaced the low pressure port Schrader valve and now need to jump the pressure switch to get the compressor to turn while adding refrigerant since the system is at 0 psi. I can't seem to find the pressure switch. Any help is appreciated.
Jeff
Old Jun 25, 2023 | 4:37 PM
not a good way to charge the system. the system should be put under vacuum and charged by weight. charging via a pressure gauge is not accurate.
you will dry start the compressor and have air in the system afterwards which will lower ac performance.
if you must; the pressure transducer is located right lower side of the condenser. its a 3 wire sensor so you will have to jump the ref and signal wires.
Old Jun 27, 2023 | 12:38 AM
oilcanhenry's Avatar
Jeff
What tech2 said is correct. You need air and moisture out of your system at MINUS -30 PSI for 45 minutes to an hour and make sure it holds at that else you have a leak. I think you can rent an A/C pump at many car parts stores.
As tech2 said, the air in the system ain't good and neither is moisture. Then you can add the R-134A back, assuming you don't have a leak. You can add a leak detector as well very easily too. 0 PSI aint gonna cut it, Jeff. You need to do this right the first time if you want a really cold A/C system working for a long time.
Dray67
May 2, 2021 1:56 PM
mkrushr
Jul 4, 2018 7:08 PM
banner1124
Jan 28, 2013 9:20 PM
Arizona
Jun 8, 2012 4:15 AM
harascho
May 10, 2009 8:45 AM
