Audio issue
Old Feb 6, 2020 | 6:41 PM
Ndahl2020's Avatar
Default Audio issue
I've had my truck for about 8 months, but as of about 2 months ago I've been having this really weird issue with my audio for the whole truck. It's a 2016 chevy silverado. If I'm driving my truck and stop somewhere and turn it off, and then go to leave again within 30 min of shutting it off, my audio cuts in and out. My radio plays for a second and then stops and then starts again, almost like a bad reception. My bluetooth will connect and I can make a call when hear half a ring but then it cuts out, for each ring. When the person answers I cant hear them. My blinker sounds funny, it starts normal but then goes quiet and then after a couple clicks it gives a loud one and then repeats. I never have this issue first thing in the morning leaving for work or at the end of the day leaving work, only when I've driven it, turned it off and try to turn it back on within a half hour or so. My brothers tried playing with the connection wires in the glove box but nothing changed. Has this happened to anyone or does anyone know how to fix it??
Old Feb 7, 2020 | 1:35 AM
Contra's Avatar
What screen do you have the 6 or 8 inch?
Old Feb 7, 2020 | 9:02 AM
Ndahl2020's Avatar
I believe it's the 8 inch, but I'm not entirely sure. Heres a pic of it
Old Feb 7, 2020 | 9:17 AM
Contra's Avatar
Yeah I believe that's the 8in which is what I have I'm not having any problems with mine you. you should probably go back to the dealer and tell them about the problem and have them look at it unfortunately it's probably going to cost you a bit.
Old Feb 19, 2020 | 1:55 PM
SkeeterHawk01's Avatar
Probably a bad DIN connector/connection on the back of the radio.
Old Feb 19, 2020 | 2:04 PM
Ndahl2020's Avatar
But wouldn't that effect the audio at other times and not just specific times? I literally never have an issue unless I try turning the truck back on within a half hour of turning it off. It's almost like it doesn't shut off properly so when I try and turn it back on before its fully shut off it doesn't know what to do. I think after a half hour it must automatically cut the power as a battery saving function and that's why it's fine otherwise.
ainkurn
Dec 23, 2020 8:57 AM
Oxpocket
Jun 6, 2017 6:23 PM
Oxpocket
2014 - 2018 (GMT-K2)
Jun 6, 2017 6:19 PM
cygh
Mar 11, 2016 10:42 AM
burntheobedient
Sep 8, 2014 1:38 PM
