Cam Swap Chopacabra DOD Delete p0089 & P228D
Old Mar 13, 2025 | 2:57 AM
Niajae's Avatar
Default Cam Swap Chopacabra DOD Delete p0089 & P228D
2017 gmc sierra 5.3
dod & cam swap. Went with chopacabra. I have codes p0089 and p228d. Ive actually recently got a p0106 which I believe would just be due to it having so much fuel making fuel air ration out of control. I’ve replaced HPFP and Fuel pressure sensor on the rail. Scanner says desired fuel pressure is 580ish which seems low, but it’s getting 1800. Going into engine reduced power. Any tips? Anyone else have similar issue? Low side pressure around 50psi. Could the issue be pcm related?
georgecampa23
2014 - 2018 (GMT-K2)
Aug 6, 2024 12:32 AM
Christian Edwards
Jul 22, 2021 4:58 PM
Sabastien Valero
2007 - 2013 (GMT900)
Nov 3, 2019 12:26 PM
Kaintuck
Sep 6, 2017 7:19 AM
chevytruckman2004
Jun 2, 2014 10:45 AM
