Causes of gas in my oil
Old Apr 9, 2024 | 6:12 PM
Keelover's Avatar
Default Causes of gas in my oil
Hello all, new member here hoping to learn about Silverados 5.3 L. I have a 2014 5.3 and my oil level seems to rise on my dipstick it smells a little like gas and I'm almost positive it's not coolant because my coolant level stays the same always. I'm wondering if faulty seals on my fuel injectors or a faulty injector could be the cause of this. Any other directions I should go as far as finding the problem?
Old Apr 9, 2024 | 6:37 PM
do you have any other symptoms?
malfunction indicators? Rough idle or misfiring? Smoky exhaust or sooty tailpipe? Have you check fuel trims with a diagnostic tool?
Although faulty/dripping injectors could certainly cause an issue, oil dilution usually just caused by excessively rich mixture (have you changed your air filter and cleaned out the intake?) . Bad seals would cause fuel outside the engine, not inside. The other possibility is too much blow-by.
Old Apr 9, 2024 | 9:46 PM
Keelover's Avatar
The truck runs very well with no symptoms that I can tell. No diagnostic lights are on. I will check the air filter and clean the intake I have just recently bought the truck. I have not checked any fuel parameters I don't have that equipment. I have a basic OBD tool that can check fault codes and turn off check engine lights but that's about all it does. I'm guessing a blow-by problem would be the worst of consequences. The level on my dipstick seems to go up fairly quickly. About a half a quart in the last 400 miles or so. I really don't feel comfortable driving it that way
Old Apr 9, 2024 | 10:02 PM
I don't blame you.
Is it a flex fuel engine by any chance?
Old Apr 9, 2024 | 10:15 PM
Keelover's Avatar
Possibly a PCV valve problem? The exhaust does not seem excessively black or abnormal
Old Apr 9, 2024 | 10:16 PM
Keelover's Avatar
I don't believe it's flex fuel but if it has the Yellow gas cap that means it is doesn't it? It does have a yellow gas cap
Old Apr 9, 2024 | 10:23 PM
Keelover's Avatar
Yes gas cap says it uses E85 if you want but there's no nomenclature on the truck itself saying Flex Fuel which I've always seen in the past. Guess I better enter the VIN number and find out and maybe take it in for a diagnostic check that you mentioned about the fuel parameters. Thanks much for your advice I appreciate it
Old Apr 9, 2024 | 10:31 PM
maybe. I could see if there were excess vacuum in the crankcase.
Yes gas cap says it uses E85.... maybe take it in for a diagnostic check that you mentioned about the fuel parameters. Thanks much for your advice I appreciate it
yeah there you go. I have 2013 5.3 with FF too and it's constantly bugging out and running too rich.
pay special attention to the alcohol content.
There is a technical bulletin about it. It will suddenly jump to 70% or more (despite using regular E10) and cause the engine to start dumping fuel.
GM's "solution" is to clear the parameter and carry on. Of course the problem just keeps returning. I really goddamn hate all this green bullcrap.
Old Apr 10, 2024 | 7:02 AM
Keelover's Avatar
Going to replace the PCV valve and clean out the intake and go from there. The truck only has 96,000 miles on it. I thought I got a beauty but I guess looks can be deceiving
Old Apr 10, 2024 | 2:19 PM
Find a scan tool and check the alcohol content parameter. If it's too high you'll roast your catalytic converters.
