Low MAF Reading?
Old Today | 8:19 AM
Gbuck1494's Avatar
Default Low MAF Reading?
Hi Guys,
New to this forum and somewhat new to Chevy trucks in general. I recently found using my scan tool that the MAF in my 2016 5.3 Silverado (130,000miles) is reading 0.46lbs/m ( 3.48g/s) which I believe to be considerably low for these truck. I had the truck smoke tested and do not believe there to be any vacuum leaks and I decided to replace the MAF sensor with a brand new OEM one and I am still getting the same readings. Any incite as to what could be the culprit of my low MAF reading?
Additional & Possibly pertinent info, the truck seems to have lost quite a few MPG within the last several months currently averaging around 12.7MPG around town and I have also noticed when on certain occasions it seems to fall flat a bit, in other words lacks the "normal" power and seems not to give a max downshift at WOT like it previously did. Again Not sure this is related or not just figured the more info the better.
Freshmac
Mar 26, 2025 9:03 PM
Nauj
2014 - 2018 (GMT-K2)
Mar 22, 2024 9:28 PM
scrnchr
Jan 26, 2012 10:43 AM
USR_BS
May 27, 2010 10:46 AM
Mike Sigmond
May 2, 2009 2:27 PM
