Oil pressure up and down On 2014 Silverado 5.3.
Old Feb 27, 2021 | 9:28 PM
Rickyw's Avatar
Default Oil pressure up and down On 2014 Silverado 5.3.
I have a 2014 Silverado, and I’m not sure when it started, but I recently noticed that the oil pressure while driving is around 40, and when I come to a stop (idle) it drops to around 25. I carried to the shop and they told me that this normal. Has anyone else had this problem?
Old Feb 27, 2021 | 10:26 PM
Welcome from Florida. My 2013 is about the same.
Old Feb 28, 2021 | 5:51 AM
hanky's Avatar
This is pretty much ,normal.
What grade of oil are you presently running in the engine?
Old Feb 28, 2021 | 10:05 AM
Rickyw's Avatar
I use 0w-20 mobil1 and Mobil oil filter
Old Mar 6, 2021 | 10:48 PM
cctwb's Avatar
If your oil is at correct level check the oil sensor. I have a 13 and had the same things happening until it totally went. My pressure dropped to 0 and I freaked. After some trouble shooting and thinking it through I figured it was the sensor. Not very expensive but dam hard to get to. Its on the center of engine by the fire wall down halfway above drive shaft. Prices I got were from 380 (Goodyear) to over 600 (Tire Kingdom). If you can reach it you can do it. I have a mobility issue. I had the auto hobby shop on a military base fix it for 140.00.
Impala-Blue-2.
Feb 24, 2018 8:49 PM
SMOKY919
2014 - 2018 (GMT-K2)
Jul 18, 2017 9:35 AM
stewie
Apr 4, 2016 10:57 AM
dgriffith
Mar 11, 2015 12:46 PM
Flea
Jun 23, 2010 8:17 PM
