Is it possible to make the 12v cigarette lighter port on main dash to be switched vs
Old Apr 29, 2021 | 2:53 PM
SSgtWeasel's Avatar
Default Is it possible to make the 12v cigarette lighter port on main dash to be switched vs
Purchased 2021 1500 LT last night
Is it possible to make the 12v cigarette lighter port on main dash to be switched vs always on?
It appears to be hot constantly
Old Apr 29, 2021 | 5:12 PM
kevinkpk's Avatar
My 03 suburban is the same, both on all the time, and I'd like to have one switched with key on for backup camera. Yes, it is possible with rewiring the socket you want switched to a switched key on circuit. Along with that two things, either splice into the battery + with key on circuit, add fuse, or splice into a key on battery + downstream of a fused circuit. With the later, you need to be aware of the load.
Old May 5, 2021 | 8:03 AM
V8powa's Avatar
yes there is a youtube on this, simply pulling fuse and changing position on the fuse block does this
tnole
Aug 22, 2015 5:39 AM
jash
Dec 10, 2012 9:51 AM
steph66
May 19, 2010 3:31 PM
ChevyguyArmen
May 3, 2010 8:24 PM
MACK5150
Mar 8, 2009 4:47 PM
