Silverado Rear turn Indicator Failure
Old Mar 26, 2017 | 10:37 AM
Jon-Michael Morgan's Avatar
Default Silverado Rear turn Indicator Failure
Whenever I put a turn signal on in my 2015 Silverado 1500 LT I will get a service notice on the DIC saying that there is a Left/Right rear turn indicator failure but whenever it says this I check the taillights and the indicators are working just fine. Any ideas on why it would tell me there is a failure when they are working just fine? I have aftermarket taillights but I don't see how that would affect the electronic signal from the actual lights.
Old Mar 26, 2017 | 1:32 PM
Are your aftermarket taillights LED's?
Old Mar 26, 2017 | 3:55 PM
Yeah they are, didn't even consider that till you said it. Do you know of a work around to keep it from giving me that notification?
Old Mar 26, 2017 | 9:25 PM
There are resistors made for LED lights. That probably will work because LED lights don't have the resistance of regular bulbs.
Old Mar 26, 2017 | 9:29 PM
I took the tail lights off and the resistors were already plugged up and I tried switching the wires they were connected to and still had the problem. They are Anzo USA tail lights and the only thing I can see that might be causing is the dealer placed the resistors on the actual tail lights instead of the body of the truck.
Old Mar 26, 2017 | 9:42 PM
Did it start doing this right away after installation? Maybe the resistors are the wrong value for the truck. Do you have LED bulbs in the front also?
Old Apr 21, 2020 | 8:12 PM
Zoltar The Decimator's Avatar
The same problem happened to me right after I replaced my battery. Lights are working but just blink faster when error appears after about three seconds.
Old Aug 8, 2020 | 2:02 PM
Courtney Veinotte's Avatar
I just replaced my bad battery today, and it’s currently doing the same thing, did you find a fix ?
Old Nov 30, 2020 | 2:45 PM
Anthony Williams's Avatar
My battery ran dead last night, and I had to jump start it. My turn signals are doing the same thing, what did you find fixes it?
Old Mar 24, 2024 | 8:57 AM
shirlbuxb's Avatar
I broke the tail light cover, replaced it with the same bulb (the bulb didn't break ) Now I'm getting error message saying: left turn indicator failure? But the lights, blinkers, etc...still work, blinker blinks fast though?
Any advice?
