2020 Silverado custom rattling under bed
Old Sep 15, 2020 | 6:43 PM
Tjsaenz's Avatar
Default 2020 Silverado custom rattling under bed
I have a new truck with 1000 miles on it. At 500 miles a terrible rattling coming from under the bed started. It happens when I turn and hit a bump. I took it to a dealer and they kept it for 3 days then came back and said it was normal. Know way it’s normal and it’s getting louder. They said the noise was coming from the rear axel but it’s normal. Any idea what it might be? What else should I do? I’m thinking about taking it to another dealer. It’s very frustrating and I bought a new truck to avoid issues.
Old Sep 21, 2020 | 1:53 AM
JRT600's Avatar
I would check the heat shields around the exhaust system. Also wiggle every piece of metal under the truck to see if anything is loose. Jump up and down on the rear bumper to see if you hear the rattle. If you still cannot find it, take it to another dealer. Rear axel rattling, then they should fix it. It is not normal.
Old Sep 23, 2020 | 12:17 PM
Tjsaenz's Avatar
Got it figured out and fixed. Not sure why the first dealer couldn't help. It was the drivers side leaf spring. They had to put an insert to correct the problem but it was an easy fix. Thanks for the suggestions.
Old Oct 9, 2020 | 5:00 PM
I Drive a Truck's Avatar
Default We have 2016 Chevy
Our Chevy has a bad rattle in the frame on passenger side door frame somewhere and we can’t figure it out. Seems like Chevy is building cheaper trucks these days. Plus we always have problems with the trucks trailer brake system.
Any ideas?
Old Oct 9, 2020 | 9:07 PM
check if the lock rods inside have come loose
Old Oct 9, 2020 | 9:25 PM
chevyboy@22's Avatar
Default Silverado Rattling
it's the leaf springs... they all do it once they get dirt in them.
Old Nov 6, 2020 | 11:32 PM
PJT76's Avatar
Default Rattling under bed
I have a 2019 Apex model and mine has a rattle under the bed too. I haven't had time to check it out yet. I have taken it in once and they can't find anything. A friend of mine has a black widow and his had a sound under the bed and it turned out to be the axle on his.
Old Nov 7, 2020 | 12:01 AM
the rubber pads fall out and the rebound clips rattle too
Old Nov 7, 2020 | 7:57 AM
try another dealer. if they say the same thing, have them show you its normal by testing driving with you in another identical truck.
eric wrighter
2019+ Silverado (GMT-T1)
Feb 14, 2020 4:40 AM
c_pps_2k
Colorado
Apr 6, 2015 9:37 PM
Joanna
Nov 4, 2010 10:20 AM
Seattle-Silverado4x4
Sep 15, 2010 7:43 PM
jpo138
Jan 8, 2007 11:11 PM
