2021 Silverado AC Issues
Old Jun 8, 2024 | 9:35 AM
amznazn89's Avatar
Default 2021 Silverado AC Issues
I have a 2021 Silverado RST with 5.3 L motor. AC stopped working blowing hot air over memorial weekend shut the truck down for two days pulled fuses and relays and the AC was blowing cold again. The AC worked for about one week, then stopped blowing cold air and blowing hot air again, I took it to the dealership and they mention the fan clutch seized up, causing damage to the compressor and replace the compressor cost $2400. No leaks on the system and didn’t test any sensors just leak test.
To me a failed fan clutch wouldn’t cause the intermittent issues and no noise was observed before ninjas the first issue, when it was working or when it went out again. I hate to think about paying 2400 to replace the compressor and another month later it’s going to need a evap temp sensor and another $2000.
The truck is 2.5 years old and for a mechanical break doesn’t sit well with reliability of these trucks.
Old Jun 8, 2024 | 9:43 AM
Rednucleus's Avatar
Find a reputable shop for proper diagnosis assuming out of warranty
Old Jun 8, 2024 | 12:56 PM
amznazn89's Avatar
Default Dealership
Out of warranty by mileage not years. Chevrolet dealership is quoting 2500 and diagnosis is bad clutch and compressor. No leaks but said nothing about checking the electrical side.
Old Jun 8, 2024 | 10:55 PM
chem_man's Avatar
15 Year Member
I would take it to a shop that specializes in AC and see what they have to say about it and how much they would charge.
Old Aug 7, 2024 | 6:29 PM
txmetal's Avatar
Has it worked again at all? Mine is intermittingly working on and off, I was told these variable compressors are bad about the electronics going haywire and doing this, the bad news is you have to replace the compressor to fix the electronic issue, good news is if it is that issue you have no risk of it messing up the system and can just replace the compressor. If it starts working again and is cold then goes warm again i would get a shop to test the electronic side of it.
Old Aug 8, 2024 | 9:36 PM
heavychet's Avatar
$2400 seems steep for a compressor replacement. maybe shop around a bit? i've heard some independent shops can do it for less. just make sure they use quality parts and know what they're doing with newer vehicles.
3Js
Oct 28, 2022 5:52 PM
Birdman01
1988 - 1998 (GMT400)
11
Mar 12, 2022 11:40 AM
Harley75
Jun 18, 2019 5:48 AM
mike70t
Aug 13, 2017 6:18 AM
Zach
Aug 7, 2011 7:29 PM
