TrailBlazer 2002-2009
Ac not working
Old Jun 15, 2019 | 3:55 PM
Harley75's Avatar
Default Ac not working
Compressor runs worked a few days ago now hot air out of all vents no cold air
Old Jun 15, 2019 | 8:53 PM
oilcanhenry's Avatar
Do you you have any R134A pressures at all? Magnetic clutch working?
Old Jun 16, 2019 | 5:08 AM
Harley75's Avatar
Has the right amout of freon in it the only thing i did was the other day was chilly so i bumped the control for warm air then after that now no ac.I even tried to do a reset pull the fuse compressor cycles like it should hit the ac botton and it comes on got about 37-39psi
Old Jun 16, 2019 | 6:01 AM
Thats the low-side. Are either A/C tubes getting cold or hot? Might be a restriction of some kind.
Might also be a stuck heater control valve as well.
Old Jun 16, 2019 | 6:27 AM
Harley75's Avatar
Where is the heater control valve what controls from hot to cold
Old Jun 16, 2019 | 9:33 AM
Harley75's Avatar
Think i found it got some acpro now shot some in to it got to 35psi waited 5minutes it droped back down to 25psi now if i had a bad leak like that i would see a small cloud of white i think it was just that low.So going to.check it everyday for 2 days if it holds at 25psi then it was low low on freon.
Old Jun 16, 2019 | 9:37 AM
If you have a traditional heater control valve it will be located near where the heater lines enter the firewall. Things have changed and since I am not familiar with the Trailblazer
its possible that its elsewhere. Might want to make sure that your heater/AC actuators are working properly as well.
Old Jun 16, 2019 | 2:38 PM
Harley75's Avatar
What should the low side read the whole system calls for 2.65 pounds right now reads 40psi with it being 80deg here.But inside temp is 68.5 not right something going on
Old Jun 16, 2019 | 9:27 PM
At 80 F and depending on humidity, 35-40 PSI on the low side is normal. High side should be at 175-210 PSI depending on the system. Do you have access to an A/C gauge set? Also a can of leak detector dye might be a good idea. Outlet temps on a good system will be 45 F or less.
Old Jun 17, 2019 | 4:21 AM
Harley75's Avatar
Inside temp 68.5 might have.a clog
