TrailBlazer 2002-2009
Ac not working
Old Jun 17, 2019 | 5:18 PM
  #11
oilcanhenry's Avatar
Originally Posted by Harley75
Inside temp 68.5 might have.a clog
You need a high pressure gauge set on it
Old Jun 17, 2019 | 5:35 PM
  #12
Harley75's Avatar
High pressure is 150psi
Old Jun 17, 2019 | 10:37 PM
  #13
Thats a bit on the low side at 80F ambient temps. At 80 F high side should be 170 PSI or more. Might want to add a bit more R-134A. You can buy a cheap thermometer that you stick in the dash outlet vent. If its more then 45 degrees F, its not putting out enough cold air for some reason. Should be no more then 42F, and 40 to 38 F is optimal output.
Old Jun 18, 2019 | 5:48 AM
  #14
Harley75's Avatar
I want.to.get.it.sucked out and check orifice tube
