Idle issues/ new truck
Old May 1, 2022 | 8:45 PM
PetersEpistle's Avatar
Default Idle issues/ new truck
Greetings. Around 500 miles ('22 Silverado 5.3l) and there seems to be an occasional misfire like system at idle. Any ideas? This is a brand new truck.
Old May 2, 2022 | 2:53 AM
oilcanhenry's Avatar
Since you paid for the warranty on your Chevy, just take it to the dealership. It might be in there a while, but it's their problem, not yours, Best of luck!
Old May 2, 2022 | 9:12 AM
Thank you for reaching out to me. I will do as you say. The only thing, though, is this idle issue may be intermminte, and therefore, dealer may say there's no problem if symptoms are not present when their Technicians will look at it. But, again, thank you for responding. To the dealer it will go if this happens one more rime.
Old May 4, 2022 | 10:52 PM
Return from dealer yesterday, problem that I described a few days ago still occures.
Old May 5, 2022 | 12:25 AM
I'd put a vacuum gauge on it. Yeah, it's old school, but it often works, If it fluctuates then something is amiss. Could be an air leak, or a spark plug not gapped correctly. Could also be the fuel injection system. I'd go down to a parts store and borrow an OBD II scan-tool.
Old May 5, 2022 | 1:27 AM
You're right; it may as well be a vacuum leak. Will check it out and post my findings in a few days or so.
Old May 11, 2022 | 2:58 AM
chem_man's Avatar
15 Year Member
If you have an android device, purchase this Bluetooth ODBII dongle from Amazon:
Amazon Amazon
and purchase the Torque Pro App from the Google play store ($5.00), and start collecting and recording engine data such as cylinder misfire counts for each cylinder, MAF data, MAP data, RPM data, engine coolant temperature data, oxygen sensors data, fuel pump pressure readings, long and short term fuel trim information, etc., Then look over the data for the problem you describe and when you find something that correlates to the condition, take your truck and the data to the dealer and show them. That will give them extra information to zero in on the cause.
FYI, I just purchased a 2002 Silverado 1500 Crew LT 4WD with the 5.3L engine and that is how I would proceed in a case like this. FYI, I'll be taking physical possession of it in the next couple of days,
Old May 11, 2022 | 12:21 PM
Default Idle Issues
Thank you for the advice
Old May 15, 2022 | 12:40 PM
Default Rough idle issues
After second return from dealership shop in relation to the cold start rough idle issue, and according to the technicians repair order, there is a document #19-NA-044 which states because of DFI system GM has revised the cold start control system to reduce cold start emissions; therefore, it is considered normal for rough idle at cold start up. Thanks to all that responded to my concerns on this tpoic.
Old May 15, 2022 | 6:18 PM
chem_man's Avatar
15 Year Member
Angry
Thanks for letting us know! I really appreciate it since I just purchased (or should I say went into debt) a 2022 Silverado with a 5.3L. Much to learn about it considering I came from a 99 Silverado (that was stolen about 2 weeks ago Angry)
09Tahoe_SSV
Sep 19, 2021 10:10 PM
Sethyates72
Feb 1, 2014 7:53 AM
moon i
Sep 28, 2012 7:47 PM
gonmoises
Sep 20, 2011 1:46 PM
1988 Chevy
Jun 14, 2009 10:58 PM
