Tire Rotation Fail
Old Jan 16, 2021 | 2:00 PM
  #11
kevinkpk's Avatar
I was fortunate as this place was about a mile from I-44, and that's where I was going. I knew something was not right, so I turned around took it back, and they mechanic had failed to tighten the lug nuts.
Old Jan 17, 2021 | 5:38 AM
  #12
Tim Henderson's Avatar
Default Thoughts
First, glad you and the kids are ok.
Based off my experience working in a body shop this is fixable, as others have said.
Replace items
1) Fender
2) various components on front suspension (rotor, caliper, pads, hub, maybe control arm, wheel, lugs and TWO new front tires).
Repair items
1) Door, looks minor
2) Paint, silver is a hard color match, stress perfection and a good painter will get it.
3) A very good four wheel alignment.
Check items
1) Frame and suspension connect point to the frame for bends. Minor changes make significant ificant difference on these new cars and trucks
2) Anything that may have scraped on the pavement.
3) Steering - end to end
best of luck and also thanks to your husband and you all for his service.
Old Jan 17, 2021 | 7:04 AM
  #13
Doug D's Avatar
Down the block, it's an impossibility, even if the lug nuts were not even torqued down. They'd loosen up, but not that
soon. I'd sue that little SOB and the dealership as well. They had better make things totally right, after this fiasco.
I had one lug nut come completely off. Discovered it after I had made a 350 mile trip to visit my son. We had decided to rotate the tires while at his place and that's when we found one lug nut missing on one wheel. The remaining four were tight. I had no clue how it happened as last I had checked the lug nuts were all there.
Old Jan 18, 2021 | 9:53 AM
  #14
oilcanhenry's Avatar
One lug nut gone, with the others tight wouldn't lead to catastrophic failure as we see here. I use locking lug nuts on both of my Chevy's. Just don't lose the key.
Old Jan 18, 2021 | 11:46 AM
  #15
bhendley7's Avatar
I just wanted to thank all of y’all for the advice, it really helps.
Old Jan 18, 2021 | 7:42 PM
  #16
swofford's Avatar
While I know my reply was over-reaction and some have said that it was (which I agree)... I just hope you get a proper resolution on this situation. The dealership that caused the problem is responsible and it needs to be resolved to YOUR satisfaction and not THEIRS... Please keep us updated (if possible) on how this all works out.
Old Feb 1, 2021 | 3:03 PM
  #17
swofford's Avatar
Just wondering if there is an update for this thread discussion.... Hoping for a good outcome on this....
Old Feb 1, 2021 | 3:05 PM
  #18
bhendley7's Avatar
Default Update
I finally got my truck back the other day. They repaired it and it drives as good as new. Thank you to everyone who commented.
Old Sep 30, 2021 | 10:34 AM
  #19
pbesong's Avatar
Almost happened to me on my '93 Mazda Miata once. I had just taken it in to the local grease monkey to get it inspected and apparently he forgot to tighten the lug nuts on the front left wheel. As I was pulling out of his shop, I could hear kind of a creaking in the front. I pulled off the road up the hill and looked at the wheel. Looks like he only started putting the lug nuts on as they were on the lugs, but not even close to the wheel. The only thing keeping the wheel on was the weight of the car. I tightened them up and drove back and gave the guy a piece of my mind. That's the last time I ever went there. I'm guessing as he started to put the lug nuts on he got a phone call and got distracted, but still you need to double-check before you let the customer take the car. Now I check my lugs every time I have it serviced when it involves removing a wheel. I usually have to take a pipe over the lug wrench (for leverage) and re-loosen the lugs anyway because they put them on so tight you can't ever get them off with just the lug wrench. I'd hate to not be able to remove it if I got a flat tire on the road.
Old Sep 30, 2021 | 8:51 PM
  #20
glad it worked out.
this can happen in any business. How the business handles their mess is what makes them reputable.
In Canada that would have been a $3000 to $5000 repair.
vwfye
Mar 3, 2014 11:48 AM
txguy3312
Jan 5, 2013 7:20 PM
No_Skills
Jan 1, 2011 2:09 PM
v6c2500
Jan 19, 2009 6:27 PM
