Why does my 2019 Chevy Silverado v6 sound like this
Old Oct 19, 2023 | 7:08 PM
toby1616's Avatar
Default Why does my 2019 Chevy Silverado v6 sound like this
I’m wondering why my truck sounds like this at idle. It makes a whining noise almost sounding like a bad idler pulley. It’s still under warranty so I’m i’m battling with the dealership to try to get this fixed. I suggested they changed the idler pulley, but they insisted it was the belt. The dealership has changed the serpentine belt and the water pump belt, but the sound is still there. Any info would be appreciated.
Old Oct 20, 2023 | 11:50 AM
you mean the groaning? Sounds like power steering to me. Let Chevy figure it out. It's what they get paid to do.
Old Oct 22, 2023 | 2:40 PM
toby1616's Avatar
Default !
I’ve brought the truck into the dealership three times. First time was to change the serpentine belt second time they change the belt again because they said it was bad and then the third time they changed the water pump belt. Just feels like they don’t want to look into the issue and just change the stuff that’s easy
Old Oct 22, 2023 | 6:34 PM
look up your state lemon laws. If they can't fix it in a reasonable amount of time they might have to buy it back from you.
Old Nov 24, 2023 | 12:47 PM
JRT600's Avatar
I have taken, a length of PVC pipe, put one end to my ear, and sweep the other end over the engine, till I could pin point, a sound I was looking for. Just don't let the PVC pipe touch any moving parts. I usually use a 1/2 inch or 3/4 inch pipe.
Old Nov 25, 2023 | 3:29 AM
kevin spahr's Avatar
I'm assuming you bought extra warranty other than the 3 year/30,000 mile???
Old Nov 25, 2023 | 4:22 PM
@kevin spahr
gm warranties the powertrain for 5 years/60k
emissions equipment 8 years /80k
Old Nov 25, 2023 | 5:50 PM
So sounds coming from the engine compartment (OP described as idler pulley going bad) falls under the powertrain warranty?
Old Nov 25, 2023 | 6:31 PM
OP doesn't know what cause of the problem is yet. If it ends up falling under the terms of the warranty , then yes it's covered. You have to read the fine print in your contract. They spell it out quite clearly for you.
Old Nov 26, 2023 | 9:30 AM
dpieroni3's Avatar
Is this vehicle equipped with a 10 speed trans? If so, did this noise just start recently? If so, see if it is coming from the front of the trans area. The trans oil pump is gear driven and the gears will fail and cause a growl noise. hope you find this helpful.
CBROWN307
2019+ Silverado (GMT-T1)
Mar 10, 2023 12:54 PM
blubyu88
Jul 30, 2014 1:57 AM
shetluck
Mar 14, 2013 6:38 PM
TrkMas3122
Mar 5, 2008 1:03 PM
toydriver00
Oct 30, 2007 4:10 PM
