2003 astro cargo van ventilation system
I have a problem with my 2003 astro van that sounds similar to a former post in that I only get air flow thru my defroster vents when either the a/c or heat is turned on and nothing thru the dash vents. In addition to this there is a rattling/rolling sound coming from the vent when the vehicle moves forward or reverse. Is there something broken inside the ductwork besides the possibility of a vacuum line problem?
Sound like something might have been dropped into the duct work. A nut or two could be making the rolling noise and prevent movement of the air flow doors. If you can find a place to rent one, a borescope would let you look around inside without taking things apart.
Please let me know if you figure it out. patrick
