Astro 1985-2005
Platform: M-Body
2003 astro cargo van ventilation system
Old May 19, 2011 | 9:16 AM
glener's Avatar
Default 2003 astro cargo van ventilation system
I have a problem with my 2003 astro van that sounds similar to a former post in that I only get air flow thru my defroster vents when either the a/c or heat is turned on and nothing thru the dash vents. In addition to this there is a rattling/rolling sound coming from the vent when the vehicle moves forward or reverse. Is there something broken inside the ductwork besides the possibility of a vacuum line problem?
Old May 22, 2011 | 9:20 AM
ihatemybike's Avatar
Sound like something might have been dropped into the duct work. A nut or two could be making the rolling noise and prevent movement of the air flow doors. If you can find a place to rent one, a borescope would let you look around inside without taking things apart.
Old Jun 4, 2011 | 12:53 AM
patrickmorris's Avatar
I have the exact same problem w/o the rattling. Air comes out the window defrost and the foot area but not the vents. I used to think such things were the result of and ongoing communist plot but of course I have updated to -- al quida plot;-)
Please let me know if you figure it out. patrick
Old Sep 4, 2011 | 7:11 PM
elmo's Avatar
I have the same problem found a broken vacuum line up front right side and replaced it, but still don't get air through the dash vents.
Old Mar 17, 2012 | 5:13 PM
JT Kessler's Avatar
Start from scratch and replace all vacuum lines and your problem will be solved.
Old Mar 25, 2012 | 6:47 PM
StanVan's Avatar
15 Year Member
There's also a chance of a bad vacuum line in the area of the intake manifold. It's common on Astro's for this to get cooked by engine heat.
scandisk
Astro
Jul 12, 2014 1:23 PM
smplyit
Jan 31, 2014 11:02 AM
texas57
Sep 2, 2011 4:42 PM
Texvan
Astro
Apr 23, 2011 8:53 PM
SDCA_Paul
Astro
Oct 23, 2010 8:12 PM
