Astro 1985-2005
Platform: M-Body
96 Astro Van Fuel Injection Too Rich
Old Apr 10, 2011 | 5:47 PM
lawhead's Avatar
Default 96 Astro Van Fuel Injection Too Rich
My 96 Astro van has 140K miles and runs to rich. Smoke out tail pipe, fouls plugs, hesitates and sputters. I have had a compression check, all fine, new plugs, new distributor, plug wires, spent over $800 already. Does anyone have the correct answer to solve this problem? I live on Kauai and this is my work truck. We are limited as to good mechanics on the island. Any help would be appreciated.
Mahalo
Old Apr 10, 2011 | 6:47 PM
EinST's Avatar
Welcome to the forum. Your vehicle is OBD-II compliant and thus you need to get a hold of a good OBD-II scanner, something that can read out freeze frame data and snapshots. I'm seeing some decent Equus units on Amazon being discounted to sub-$200. Without somethings like that, you'll inevitably waste money throwing wrong parts at the problem.
Old Apr 11, 2011 | 3:01 PM
lawhead's Avatar
Thanks very much! Shouldn't the mechanic have this? To be perfectly honest, I have no idea what OBDII compliant is. The engine light is on, is that the same scanner for that?
Old Apr 11, 2011 | 5:15 PM
EinST's Avatar
A dealership service department would have the Tech 2 scan tool that does practically everything but make breakfast. A mechanic should have something similar. Now, if you're as green with OBD-II as you claim and your mechanic seems lost, find another mechanic or, better yet, take it to a dealership service department. You're risking further damage by dillydallying.
Old Apr 11, 2011 | 9:38 PM
lawhead's Avatar
I talked to the mechanic and he does have this scanner. The message was 'multiple engine misfire'. He said it's a process of elimination which is a big labor cost for me. He put in a distributor but then took it out as that wasn't the problem. He said next he will try a 'crank angle sensor'. Nothing has 'told' him why the fuel is dumping. I have already invested so much money with this guy I hate to start over with another garage.
Old Apr 11, 2011 | 9:52 PM
EinST's Avatar
Okay, then, see if you can post the freeze frame data that goes with that P0300 code. Or, ask him to check the knock sensor if there is unusual ignition timing retardation going on. I've seen more than once the knock sensor being the cause of the mysterious timing retardation and fuel dumping.
Old Apr 12, 2011 | 7:32 AM
ihatemybike's Avatar
Was it a new distributor, or just a cap and rotor? Inspect the gear on the distributor for wear.
The P0300 is also a result of gummed upped fuel injectors. Try a Seafoam treatment or two. If that fails, GM has some stronger stuff called GM Fuel System Treatment Plus.
Old Apr 23, 2011 | 1:37 PM
lawhead's Avatar
Thanks to everyone for their suggestions. We FINALLY got the right fix after many hours and dollars. Hope the answer helps someone else. Wait for it.....
THE FUEL PRESSURE REGULATOR was leaking internally.
So there it is. Mahalo and good luck.
Old Apr 23, 2011 | 8:56 PM
EinST's Avatar
Congrats. Thanks for the update.
Scottsdale84
Nov 20, 2014 8:13 PM
acs55812
Aug 25, 2011 4:22 PM
93ShagginWagon
May 31, 2010 2:19 AM
majorlee
Astro
Nov 5, 2009 8:07 AM
starship tahoe
Jul 23, 2007 8:48 AM
