Astro 1985-2005
Platform: M-Body
97 Astro will not always shift out of park
Old Feb 12, 2011 | 7:04 AM
Overnite's Avatar
Default 97 Astro will not always shift out of park
Hello everyone, I have a 1997 Astro that will not always shift out of park. I think it is an electrical problem of some kind because when it acts up I can turn the steering wheel back and forth a few times and hit the brake and it will drop into gear. If there is a problem in the steering column I could sure use some help. Any ideas anyone? Thanks for any help.
Old Feb 12, 2011 | 3:48 PM
jimmydow1's Avatar
could be a problem with the brake pedal switch? does the shifter lock up in the "park" position?
Old Feb 12, 2011 | 7:02 PM
Overnite's Avatar
Thanks for the reply. The shifter locks in the park position. When it acts up, I can hit the brake pedal several times and it will not release and drop into gear, but if I move the steering wheel side to side then hit the brake it will go into gear.
Old Feb 12, 2011 | 8:32 PM
jimmydow1's Avatar
does the steering wheel lock up also? if it frees up after wiggling it could be a loose harness or faulty shift lock solenoid?
Old Feb 13, 2011 | 8:17 AM
Overnite's Avatar
The steering wheel locks up just fine. When I start it the steering wheel unlocks with no problem and I have never had any problems turning the key. Is it a big job to pull the steering wheel off to check the wiring? Thanks again for your help.
Old Feb 13, 2011 | 8:35 AM
jimmydow1's Avatar
its not that bad but you will need a steering wheel puller
Old Feb 13, 2011 | 10:40 AM
Overnite's Avatar
Thanks, I will get the wheel off and see if there is something wrong. I guess I should replace electrical components while I have thing apart.
Disastro2000
Astro
Feb 17, 2024 7:11 AM
damone
May 8, 2021 12:36 PM
JPod
Jun 24, 2019 6:51 PM
andrewmccluskey
Jan 15, 2014 2:08 PM
hotwheeler187
Jul 21, 2009 4:57 PM
