Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Engine Fan Clutch
Engine Fan Removal
My service manual for the 96 Astro 4.3L engine tells me I need a special removal tool for the engine fan/clutch assembly. Where can I get this tool - or is there an easy way to remove the entire fan assembly?
I don't use a special tool. I use a big ol adjustable wrench and a large box end wrench (usually grab the 20mm).
The box end is placed over one of the four bolts for the water pump pulley in position to pull the pulley clockwise thus keeping the pulley from spinning and the adjustable is use the the big nut to turn the fan assembly count-clockwise.
Dude you don't need to rent, buy or barrow anything. Sometimes this site gives people so much unnecessary advice, an have people running around for no reason. Just use a wrench that fits the fan nut, an just smack it with a metal hammer an it's a done deal just unscrew it. Problem solved
pdrayton
May 29, 2013 7:55 PM
You can rent the J tool or equivalent fan clutch wrench from some parts stores. Without it there's no way to keep the water pump pulley from turning.
