Astro 1985-2005
Platform: M-Body
Old Jul 24, 2015, 4:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Engine Fan Removal
Old Oct 12, 2011 | 12:07 PM
RobertShumaker's Avatar
Exclamation Engine Fan Removal
My service manual for the 96 Astro 4.3L engine tells me I need a special removal tool for the engine fan/clutch assembly. Where can I get this tool - or is there an easy way to remove the entire fan assembly?
Old Oct 12, 2011 | 10:08 PM
EinST's Avatar
Welcome to the forum. You can rent the J tool or equivalent fan clutch wrench from some parts stores. Without it there's no way to keep the water pump pulley from turning.
Old Oct 13, 2011 | 10:50 AM
Thanks....appreciate your time and knowledge
Old Oct 13, 2011 | 5:41 PM
EinST's Avatar
You're quite welcome. Hope it works out for you.
Old Oct 22, 2011 | 9:28 AM
ihatemybike's Avatar
I don't use a special tool. I use a big ol adjustable wrench and a large box end wrench (usually grab the 20mm).
The box end is placed over one of the four bolts for the water pump pulley in position to pull the pulley clockwise thus keeping the pulley from spinning and the adjustable is use the the big nut to turn the fan assembly count-clockwise.
Old Oct 24, 2011 | 2:02 AM
Thanks for the update...now I don't have to rent the "special" tool (aka spanner wrench)...water pump replacement went well...210k miles daily driver should last for another 150k
Old Oct 23, 2023 | 1:49 PM
Greg072500hd's Avatar
Default Fan clutch
Dude you don't need to rent, buy or barrow anything. Sometimes this site gives people so much unnecessary advice, an have people running around for no reason. Just use a wrench that fits the fan nut, an just smack it with a metal hammer an it's a done deal just unscrew it. Problem solved
Larrycarol
Jun 5, 2016 3:23 PM
pdrayton
May 29, 2013 7:55 PM
djmnm310
Jul 8, 2010 10:17 AM
hayseed
Dec 28, 2009 2:22 PM
samii
May 12, 2009 3:11 AM
