Astro 1985-2005
Platform: M-Body
No damage to ecm!
Old Mar 31, 2014 | 7:15 PM
Chevy333's Avatar
Default No damage to ecm!
The astro van is a 2001 Coming behind someone's work. It did crank. It did run at idle only for a bit. I lost communication with them ecm. No lights on the cluster ( service engine soon etc.) No fuel pump relay power.
Apparently the ecm is not getting proper ground. Using a wire with clips at both ends I grounded the ecm case to the chassis and got back communication to the scan tool, fuel pump runs and the service engine light is back. I did not install the starter so I removed it. There were three wires attached. I removed the medium sized wire and now have proper ground without using the wire with clips to the ecm housing.
It starts and wants to run but I am aware the exhaust return to the intake is missing. This pipe
[/URL][/IMG]
87camaro
Apr 16, 2020 1:55 AM
Chevy333
Astro
Mar 31, 2014 7:17 PM
Chevy333
Astro
Mar 30, 2014 4:54 PM
pervitizm
Sep 23, 2007 11:05 PM
crewguy
May 23, 2007 11:22 AM
