Astro 1985-2005
Platform: M-Body
transfer case leaking
Old Feb 15, 2008 | 1:02 PM
fleetline51's Avatar
Default transfer case leaking
Newbie
My 2000 Astro awd is leaking fluid from the transfer case. I filled it about two weeks ago with 2 litres of Auto-Trak(blue) fluid.
I now see large leak spots on the ground where I park and when I pull away,I can see a visible trail of fluid leaking.also on long trips(highway speeds) I notice "oil" spots on the rear door window.As I look under the van,I notice a good deal of fluid
on the undercarriage around the transfer case and other areas as well.
any help? Thanks,Tony
Old Feb 18, 2008 | 8:42 AM
EvansBlue's Avatar
Default RE: transfer case leaking
Check the plug, gasket, and the places where the case is bolted together.
Old Feb 21, 2008 | 7:38 PM
ktm521's Avatar
You will have to clean it up and watch for the leak, it could be the seal or the case halves. If its the case halves i wouldn't use anarobic sealer like it calls for, use silicone and let it dry before reinstalling.
TahoeLTGuy01
Nov 2, 2014 12:24 PM
white03
Oct 21, 2013 2:29 PM
Chevy_Joe
Feb 26, 2012 2:22 PM
fsh4fun05
Aug 20, 2010 12:46 AM
89k5blazer
K5 Blazer
Oct 15, 2009 8:28 AM
