Audio/Visual Electronics Wired up? Got a cool sound system? Discuss all your Audio, Video, and other cool electronics here! Please limit the contents to aftermarket only. If you have questions that pertain to a certain model, post it in a model-specific section.
08 sierra DVD Nav installation
Old March 16th, 2008, 11:19 PM
cieboard's Avatar
Default 08 sierra DVD Nav installation
Anybody have directions on installing a DVD, Nav system and the wiring diagrams in a 2008 model year.
Old March 17th, 2008, 7:47 PM
Banned
shawnvw's Avatar
Default RE: 08 sierra DVD Nav installation
https://chevroletforum.com/m_5604/tm.htm
Old May 15th, 2008, 5:34 PM
Mike E.'s Avatar
Hello:
I to am trying to install a GM Nav. unit in my 2008 GMC Sierra. I came without the Bose system. Here is a link I found that will help,
GM Nav Install Guide
My $#@% dealer cannot remove the Theft Lock message so still no sound but the install is done!
Thanks and good luck.
Mike
Edit by - rabbit0102030 **Fixed long, drawn out, two lines long link. Please use the tag functions when posting pictures and links.**
Old May 16th, 2008, 2:43 PM
Banned
shawnvw's Avatar
Mike....tell the dealer to connect the Tech2, build the vehicle as a 2006, cheverolet, W Body, Monte Carlo LTZ, select body & accessories, Entertainment, Module setup, Radio, VIN Relearn
This should unlock the radio and make it work for you
Old May 20th, 2008, 9:49 PM
charlie pachanga's Avatar
Unlocking the theft lock by trickingthe radio into thinking it is in a 06 monte carlo. Will unlock radio, but you will not have any of the vehicle cabin eq setting for a pickup.
You alsorun the risk of not getting any sound from the audio (amp or bose lux amp). The audio will only work if vehicle is non amplified, just not enoughbass output.
To make it sound right you need to connect itto GM tech 2 with candi module and as a pass-thru with gm tis-2-web. build the vehicle correctly, according to the build code in glove box.
I think gm requires the techs to call GM VIS to get aVIS number. The Navigation calibration is no longer supported as an option with out a VIS.
Old May 21st, 2008, 7:39 PM
Banned
shawnvw's Avatar
Accually there is a current TSB on these trucks from GM to unlock the radios this way. Using Pass-Through Programming does not work to unlock these radios. Calling Engineering to get a VCI Number is ludacris as it usually takes a couple hours to get them to build software. Not only that but they will probably tell you to stop wasting their time and just use TIS2WEB
I have done about 10 of these in the passed year and have yet to have a problem doing it this way
Old May 21st, 2008, 10:47 PM
I reprogramed one on Monday May 19, 2008. Gm no longer has Navigation calibration on TIS2WEB.
Good luck.
shawnvw
April 13th, 2021 10:27 AM
deen2vaca
April 21st, 2013 10:39 PM
Kks
February 4th, 2013 12:15 AM
cjasonsmith
February 21st, 2009 10:50 PM
DennisG
Silverado & Fullsize Pick-ups
August 25th, 2008 4:11 AM
Quick Reply: 08 sierra DVD Nav installation
