Chevrolet Avalanche
Platform: GMT 805 & 900
2007 Chevrolet Avalanche 5.3 (P0300) Issues ...need help
Old Jul 17, 2015 | 7:20 PM
niner80's Avatar
Question 2007 Chevrolet Avalanche 5.3 (P0300) Issues ...need help
Hi Everyone ,
New here on the forum. I have a 2007 Chevy Avalanche 5.3 that I purchased 4 yrs ago from a head tech at a local GM dealership here in the Wooddbridge, Ontario. They had the engine replaced at 57,000 under warranty and put a new crate motor in. The truck now has 180,000km on it and I'm having some issues.
I'm a little pissed and fighting with GM Canada for some help. I use to own a shop so in know my truck was babied and all oil changes were done at 5000km intervals with synthetic oil only.
VEHICLE RUNNING ROUGH, TRACTION CONTROL LIGHT COMES ON INTERMITTENTLY AND WHEN ON VEHICLE SHIFTS INTO 2ND GEAR ROUGH. WHEN NOT ON ITS OK. ENGINE LIGHT ON.
SCANNED VEHICLE AND GOT ...
1) P0300 Engine misfire detected.
* #2 cylinder misfiring
2) P0621 Generator L-Terminal Circuit
3) C0561 System Disabled Information Stored Invalid Serial Data Received
4) C0660 Level Control Exhaust Valve Circuit Short to Ground or Open
P0300
Checked compression #2 -150psi (running) ** When vehicle off compression is 90psi other cylinders at 120psi
Replaced spark plugs
Replaced Wires
#2 Cylinder injector resistance low compared to other cylinders. Swapped injectors to see if issue disappears and nothing changed. Wondering if this is a electrical issue? If anyone has further information is appreciated.
Old Jul 26, 2015 | 5:50 AM
remylb's Avatar
Default engine problem
i had the same problem. what i did to get rid of it was clean out your throatle body from carbin and i changed the valve cover with the pcv valve built in because it was pluge and was putting oil in the intake. if this is the not thefix it might be a wire at the throatle body
Old Jul 27, 2015 | 5:24 PM
niner80's Avatar
Yup Bad Lifter . Took it out and roller was chewed up. Replacing all the lifters and camshaft. Also Found TSB on OIL PRESSURE MESSAGE. I remember that my oil pressure once went on and gave me low oil pressure. Might of been a plugged up oil valve filter that may of started this problem. Replacing the filter and pressure switch also. I'll post up some of the bad lifter pics later.
TSB - TECHNICAL SERVICE BULLETIN
LOW OIL PRESSURE MESSAGE/LIGHT - INSPECT VALVE LIFTER OIL FILTER
Reference Number(s): PIP4786A, Date of Issue: April 10, 2015
AFFECTED MODEL(S): 2007 Cadillac Escalade, Chevrolet Monte Carlo; Built before April 1, 2006 with 6.2L L92 Engine (These engines were built with AFM Hardware but the AFM system was disabled); 2009 Buick Lacrosse Super, Allure Super (Canada Only); 2005-2007 Buick Rainier; 2007-2015 Cadillac Escalade; 2007-2015 Chevrolet Avalanche, Silverado, Suburban, Tahoe, Chevrolet Camaro SS, GMC Sierra, Yukon; 2007-2009 Chevrolet Impala; 2005-2009 Chevrolet Trailblazer, GMC Envoy; 2007-2008 Pontiac Grand Prix; 2008-2009 Pontiac G8; 2005-2009 Saab 97x; With an AFM (Active Fuel Management) V8 Engine RPO: L76, L83, L86 L94, L99, LC9, LFA, LH6, LMG, LS4, LT1, LT4, LY5, LV3
SUPERCEDES: This PI was superseded to update Model Years and Warranty Information. Please discard PIP4786.
SERVICE INFORMATION
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
CONDITION/CONCERN
Some customers may complain of a low oil pressure message/light on the dash and a technician may find a P0521 DTC in the ECM.
RECOMMENDATION/INSTRUCTIONS
If this concern is encountered, follow SI diagnosis
If it indicates that the Tech 2 or GDS2 oil pressure parameter is low but proper oil pressure is present at the oil filter housing, inspect the Valve Lifter Oil Filter for debris/sludge that could be restricting oil flow to the oil pressure sensor before replacing any parts.
Follow the Valve Lifter Oil Filter Removal and Installation Procedure to remove the filter for inspection.
If the filter is plugged, it can normally be cleaned with brake/contact cleaner and light shop air.
If it cannot be cleaned for some reason, replace it using the part number listed in the parts catalog.
Do not replace the complete Valve Lifter Oil Manifold just because the filter is plugged.
WARRANTY INFORMATION
Old Jul 27, 2015 | 5:25 PM
niner80's Avatar
Also other TSB's Found ...
2007 Chevrolet Avalanche 5.3L Eng
ACTIVE FUEL MANAGEMENT (AFM) ENGINE, VALVE LIFTER TICK NOISE AT START UP WHEN ENGINE HAS BEEN OFF FOR 2 HOURS OR MORE (EVALUATE NOISE AND/OR REPLACE AFM VALVE LIFTERS)
Reference Number(s): 10-06-01-007D, Date of Issue: April 10, 2012
Affected Model(s): 2007 Buick Rainier 2009 Buick LaCrosse Super, Allure Super (Canada Only) 2007 Cadillac Escalade Built Prior to April 1, 2006 with 6.2L Engine RPO L92 (These engines were built with AFM Hardware but the AFM system was disabled) 2010-2011 Cadillac Escalade, Escalade ESV, Escalade EXT 2007 Chevrolet Monte Carlo 2007-2009 Chevrolet Impala 2007-2011 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT 2010-2011 Chevrolet Camaro SS 2007-2011 GMC Envoy, Envoy XL, Sierra, Yukon, Yukon Denali, Yukon XL, Yukon XL Denali 2007-2008 Pontiac Grand Prix 2008-2009 Pontiac G8 2007-2009 Saab 9-7X Equipped with AFM (Active Fuel Management) and V8 Engine RPO L76, L94, L99, LC9, LFA, LH6, LMG, LS4, LY5 or LZ1
Attention: This bulletin only applies to the AFM V8 engines listed above. It DOES NOT apply to non-AFM Engines. If you are dealing with a non-AFM engine that is experiencing a similar noise, refer to Engine Mechanical > Diagnostic Information and Procedures > Symptoms in SI.
Supercedes: This bulletin is being revised to update the Correction information by removing the non-AFM valve lifter replacement and removing the non-AFM valve lifter Parts Information. Please discard Corporate Bulletin Number 10-06-01-007C (Section 06 - Engine/Propulsion System).
Superceded Bulletin(s): 10-06-01-007C, Date of Issue: November 17, 2010
CONDITION
Some customers may comment on an engine valve lifter tick noise that occurs after the engine has been shut off for at least two hours. The tick noise may last from two seconds to ten minutes.
CAUSE
This condition may be caused by any of the following:
Aerated oil in the valve lifter body, resulting in the valve lifter being unable to purge the air quickly.
A low engine oil level or incorrect oil viscosity.
Dirty or contaminated oil.
A low internal valve lifter oil reservoir level.
Debris in the valve lifter.
A high valve lifter leak down rate.
CORRECTION
If the SI diagnostics do not isolate the cause of this valve lifter tick noise and normal oil pressure is noted during the concern, perform the following steps:
Inspect the engine oil condition and level. Refer to Owner Manual > Service and Appearance Care > Checking Things Under the Hood > Description and Operation > Engine Oil in SI.
If the engine oil is more than one quart low, an incorrect oil viscosity is being used or if poor quality/contamination is observed, change the oil and filter.
NOTE:
Allow at least a two hour soak time between engine OFF and start up when evaluating the valve lifter tick noise.
Start the engine and evaluate the valve lifter tick noise.
If the valve lifter tick noise is still present, replace all 8 active fuel management (AFM) valve lifters ONLY.
Refer to Valve Lifter Replacement (With AFM) in SI.
PARTS INFORMATION
Part Number Description Qty
12632143 AFM Hydraulic Valve Lifter 8
georgiatahoegirl1980
Dec 27, 2021 7:06 AM
4tofloor
Apr 18, 2015 8:57 AM
TheSilentBeast
12
Sep 5, 2014 3:47 PM
Sarah18
Aug 19, 2013 5:51 PM
Ecssound
Jan 23, 2012 5:19 PM
