Chevrolet Avalanche
Platform: GMT 805 & 900
2012 Avalanche Key won't turn in ignition
Old Oct 19, 2014 | 5:10 PM
garygve's Avatar
Default 2012 Avalanche Key won't turn in ignition
I have a 2012 Avalanche went to start it yesterday and the key won't turn in the ignition switch. I have a extra key same thing, I can't believe a 2 year old vehicle should have a problem so soon. I'm going to have it towed to the dealer on Monday it has 57,000 miles so its out of warranty. I also had to replace the windshield wiper motor already, I wonder whats next. I will let you know what it costs for this.
Old Oct 19, 2014 | 5:42 PM
this may not be your issue but have a look at the keys. if the edges have lost the silver coating and are left with a dull brown edge...the keys are worn. typically its a 5 year time line for this to happen. have new keys cut using a key code...don't trace the old keys.
Old Oct 19, 2014 | 5:55 PM
garygve's Avatar
I have the 2nd key that came with the truck same thing, I found another post here with a 2012 pickup that had the same problem he said after trying to turn it back and forth for 20 minutes he got it to work.
Well guess what I just went out to the garage and did the same thing after about 8 minutes I got it to turn and start. I turned it off and tried again and now it works, I'm going to have to have it replaced I can't take a chance of having my wife being stranded somewhere.
I thing GM should replace it with only 57,000 miles that shouldn't happen but they won't.
Old Oct 19, 2014 | 6:06 PM
ok.
usually, if you got it to turn by jiggling its probably the key. I see this every day. key problems are far more common than lock cylinders on the pick ups. I may have replaced 1 in the trucks in 5 years but keys once a week.
inspect your key and if they are ok put some white grease in your lock cylinder to lube the tumblers.
Old Oct 19, 2014 | 6:30 PM
garygve's Avatar
ok.
I will try that and see if it acts up again, my wife doesn't use it much I just don't need it happening when she is driving it. Should I use the spray white lithium and stick the tube in the hole and spray or just wipe it on the key?
Old Oct 19, 2014 | 6:39 PM
use the tube type. new lock cylinders come with a small, one use tube. put a small dab the size of a pea in the cylinder and wipe some into the groves on each side of the key. work the key in and out and then from off to run multiple times.
Old Oct 20, 2014 | 3:39 PM
Official GM Rep
Hi garygve,
We're sorry to hear of your key concern. We understand that you have been in contact with your dealer in regard to this issue. We'd like to look further into this for you. Please feel free to send us a private message with your VIN, current mileage, full contact information, and dealer name for further assistance. We look forward to hearing from you!
Kristen A.
Chevrolet Customer Care
G T Igofast
Sep 3, 2013 3:46 PM
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
otacon28
Mar 11, 2007 1:32 AM
